Question 1
Here's a trick you can use with your mixer.
1. Take mic one and fade it all the way to the left.
2. Take mic two and fade it all the way to the right.
Then the left channel going to the computer is mic one, the right is mic 2. Split them to seperate tracks in the software then mix them back to stereo when you are done. You'll have to add the audio in post. But I would prefer doing that anyways so you have more control of it.
If your looking to upgrade what kind of budget are you looking at?
I remember experimenting with that very idea but i think oddly enough the single stream output thats being conveyed to my recording software (Cubase4 LE, SoundForge9, MixCraft, ACiD3, and Audacity) is coming out as Mono though i admittedly only experimented with the idea for 5 minutes before going onto the next major problem.
When i get home ill give it another go!
as for Budget? Im only running free podcasts (for the time being) so anything less than $500 before tax would be my absolute top mark there.
I was looking at an Alesis MultiMix 16 USB 2.0, that runs at about $450CAD, and the MultiMix 8 USB2.0 runs about $399
Of course, ive also looked at some Fostex equipment, the Fostex MR-8/HD seems like itd be sufficient enough portable Multi-track recorder so i could setup my equipment most anywhere but that thing gets a little pricey at $599CAD (depsite the online stores saying its like $299USD
I plan on upgrading not just the core mixer either, replacing all the Mics with even cheap Sennheiser E815S Microphones would make me overzealous in happiness, but getting a few Sennheiser HD201 Headphones for everyone to wear would just complete the package for me.
(im a pretty big Sennheiser brand whore haha)
I learned on pro-tools so I'm kindof partial to the digidesign/mbox devices.
The mbox 2 has 2 pre-amps and 2 line level inputs that it can all run simulteous.
It runs around $500, but you arent going to get much cheaper and still have 2 pre-amps (mic inputs.)
[LINK REMOVED]
Software that requires specific hardware to run always makes me a little edgy, but i do know first hand that Pro-Tools is an industry grade brand name with lots of respect behind it.
Admittedly, Alesis wasn't and isn't my first choice (ill be grabbing a Drum-Brain from them soon though) but its the best brand the store i deal with has (Wentworth Music Canada) and a far cry better than my Peavey Versamix i had before. How and why? At least the Alesis runs haha.
Question 2
If the same mix for both sets of headphones will work then just get a 1/4" splitter. If you need seperate level controlls your gunna have to get a headphone mixer or amp for the aux out.
Yeah same mix should work for all headphones to make sure everyones hearing the closest to the final product as possible. The idea is to get everyone to subconsciously lower and raise their voice to avoid complications in levels Post-Edit and allow them to alter their pitch to conform to how they want to sound on air, and i feel as long as they can hear this in real time, there shouldnt be anymore comments like "... uhh i dont want to do this anymore, i hate the sound of my voice on this thing"
Question 3
The 1/4" inputs on your mixer are mono. You will have to get a stereo 1/8th to 2- mono 1/4 to get full stereo music from your mixer.
2 mono 1/4"s? Is this a converter end? Like what specifically am i looking at here, and if you have a link to a picture or something, thatd be the best thing ever.
Thanks for allowing me your time, and i appreciate that you actually answer all the questions
Thanks man!
-k
