In the case of comparing speakers with the above specs, the 4 ohm speaker will be supplied additional power and will play louder the the 8-ohm speaker. But, it's only 2.4 db louder 10log(350/200) and not by any stretch 75% louder. Twice as loud would be about 6db, so this maybe could be called "a little louder".
Not entirely true. Low-impedance speakers (4 ohms nominal or less) may cause problems with amps/receivers that aren't designed to deliver large amounts of current. A speaker with a sensitivity rating that's 3 dB higher than another speaker's only needs half as much power to deliver the same amount of sound.
Mac said:
Originally Posted by MacManNM
87 at 4 ohms is like 84 at 8.
What he was trying to get across was that the 8 ohm 84dB speaker has an extremely low sensitivity, and will need quite a bit of power to play at reference levels. A 4 ohm nomimal impedance speaker of 87 masks (or mimics) the spl rating, being able to increase the spec 3dB and still maintain the same output as the lower sensitive 8 ohm speaker.
Think of a little Chevy Geo Metro 3 cylinder engine starting out in first gear. Now think of a Dodge Viper V10 starting out in 3rd gear. The Metro will get up to speed quicker with less power, but redline quicker, while the V10 may start out slowly, but have plenty of power well beyond the Metro. You may need more power with a 4 ohm impedance speaker, but may realize more potential with more power.
Impedance is simply resistance. Here's a better explanation from
www.electronics-tutorials.com
A simple example of impedance
Assume you have available these 4 items on your bench:
(a) A series of eight fresh AA type 1.5 volt cells to create a total of 12 volts supply.
(b) A 12 volt heavy duty automotive battery - fully charged.
(c) a small 12v bulb (globe) of very, very low wattage. and;
(d) a very high wattage automotive high-beam headlight.
Now if we connect the extremely low wattage bulb to the series string of AA cells we would expect all to work well. Similarly if we connect the high wattage, high-beam headlight to the heavy duty automotive battery all will be well. Well for a time anyway. Both of these sets are "sort"of matched together. Light duty to light duty and heavy duty to heavy duty.
Now what do you think would happen if we connect the high beam headlightto the series AA cells and conversely the low wattage bulb to the automotive battery?.
In the first case we could imagine the high beam headlight would quickly trash our little tiny AA cells. In the second case our min-wattage bulb would glow quite happily at its rated wattage for quite a long time. Why?, therein lies my expanation of impedance. Consider it!
The heavy duty battery is capable of delivering relatively large amounts of power but the series string is capable of delivering only relatively minimal power. The first is a low impedance sourceand the other, in comparison is a relatively high impedance source.
On the other hand the high beam headlight is capable of consuming relatively large amounts of power but the minature bulb is capable of consuming only minimal amounts of power.
