I'd say go for the default +2.5 (L) - +6.5 (H). If you go to the
O2 page on JDS Labs and click customize, you'll see an explanation of each of the boost level options.
There's a
reddit thread where people discuss the differences between the Massdrop O2 vs. the JDS Labs O2. I haven't seen Massdrop drop the O2 more than once, so I think you'll be waiting a long while if you hold out for that one. But I also wonder if you could order the 220v edition and just supply your own adapter? The adapter steps down the voltage to 15v anyway. You could probably find a replacement compatible adapter on Amazon (
something like this?). Or
straight from JDS Labs if you don't want to gamble on the tip being the wrong size.
FWIW, My headphone amp is the Fiio A5. It's pretty good. The bass boost is stupid on it, but it's otherwise a nice amp. The high gain setting is pretty much identical in clarity and punch to the low gain setting, and it drives my low-sensitivity Aeon Flow cans to uncomfortable levels. It was $110 shipped on eBay. I'm honestly not sure how the Fiio A5 and the JDS Labs O2 compare to each other in performance. If in your travels you come across a comparison I'd be interested in reading it. I think the Fiio is thinner and probably feels less like a homebrew project box. *shrug* Also, it appears the A5 is marginally more powerful. The O2 is max 613 mW @ 33 ohms, whereas the A5 is 800 mW @ 32 ohms. I doubt that would translate into any significant audible difference, though.
One of these days I hope to upgrade to a
miniDSP headphone amp, and maybe later get a
calibrated measurement head so I can flatten by more than just trial-and-error. Probably not any time soon though. I need to cool it on buying stuff for a while. But it would be nice to move the EQ from software on my phone to NVRAM on the amp.
