Selectable dipole/monopole via 12V trigger anyone?
A buddy of mine was listening to the 700 series from B&W and found this :) Now that is just cool:
The DS7 offers a choice of both monopole and dipole operation, either via a switch located on the front baffle, or remotely, using a 12V trigger from the surround processor. Some processors allow you to program the 12V trigger according to the type of material being played, so you can automatically switch between the two modes if desired.
In monopole mode, only the two drive units on the front face operate. In dipole mode, the front tweeter is disconnected; the two side firing drivers are brought into operation and the crossover frequency to the bass unit is lowered. The side units are connected out of phase with one another, which creates a wedge-shaped null zone at right angles to the wall. If the listeners sit within this zone, they become less aware of the location of the speakers and hear more reflected sound; hence the diffuse nature of the sound field.
Link.
M&K had done selectable bi/di and tripoles via a switch for some time also, but this is the first one I've seen that has the ability to allow a capable PROCESSOR to switch it for you via a 12v trigger. I didn't see that mentioned on those Energys.
Sheep
Sheep
Oh, yeah. But really, its not hard just to flip a switch.
Now, where would you plug those inorder to switch them?
SheepStar
AVRat
AVRat
SheepStar
It is if you're in a wheelchair! I'd like to know which processors are that capable. I know the Denon AVR-5805 has some pretty good control capabilities.
