Thanks ImcLoud,
If there are no real advantages to the 120 amps I will probably just go with the 12V. I work out of this cabin during the day and have to run the inverter while my computer and peripherals are on. When I quit working I like to turn the inverter off. I can use my lights, VHF radio and cell phone with only 12V and it would be sweet if I could add the sound system to that as well.
After pulling the tape on a few things I think that floor standing speakers are just too big for my situation and I am going to have to go with a shelf system.
What do you think of the Ascend Sierra 1 speakers and how do you think they compare to the Klipsch RB 81 models? Looks like the Sierra's are quite a bit smaller, which would be nice.
For rear vented speakers, how far away from the wall should they be?
I really appreciate your help!
b
Call Deena at Ascend she will give you any measurements you need, I love ascend speakers, they are a great value... The sierras sound really good {although for theater I prefer the 340's}... The sierras are very nice for music...
I was thinking be as efficient as possible, that is why I recomended the tektons... sens= 86.5db vs 95db for the tektons, it doesnt sound like a lot but it equates to...
If you want 92db at 5m with 3 db headroom...
The Sierras need 177 watts
the Tekton 81's will need 25 watts To make the same volume level!!!
And I am sure the tektons will sound great, you are welcome to come and listen to my Lores, everyone that hears them is amazed... 3 people bought tektons after hearing mine... All were happy...
You still have the problem of the outdoor speakers, but that shouldnt be a huge issue, just add another smaller 12v amp, and be done with it...
After doing some thinking....
Here is what I would do...
2- of these
Helix Blue B TWO 2-channel car amplifier — 80 watts RMS x 2 at Crutchfield.com
These are a/b class, and I heard them on a set of mb quarts, pretty impressive amplifier, and after doing some thinking even though the PDX is efficient, the A/B class is also eff and a better choice for your application... Plus I heard class d amps arent great for tweeters..
{"the output filter in a class D amps is always designed to a specific load impedance. Loading it with a a different impedance will affect the high frequency cut-off point. Specifically loading it with half the impedance will halve the cut-out point"}.. Stick with an a/b {that is what most home amps are}... These amps will deliver about 40w- 8 ohms although I believe Tekton can make these 4 ohm if you like...
a set of tekton bookshelf $650- I am sold on this guys designs, I know some say the Pendragons, aren't going to sound good because of design flaws {although I NEVER heard anyone say a bad thing about them, and he has sold a lot of them {you have to wait for him to finish a set}. I heard a set and they were only being powered with a 3 watt amplifier, but they sounded good... Anyway, the bookshelf design cant be disputed its that same as any other setup, just more efficient... And these will allow you to hardly work your amplifier, saving energy and sounding awesome...
for outdoors- a set of Bose 251's, I am not a bose fan by any means, but when I asked my friend about your system {he is a boat audio genius} he said these stand up to everything and sound really good, he said he had a boat pulled in that had sunk in the ocean off of Point Judith and was completely upside down for 4 days, the speakers still work to this day... I remember him telling me the story but I couldn't remember which speaker.... You can get them on ebay for a few hundred bucks...
I think that would be a really nice system... If you decide on the ascends you will want a larger amplifier, but helix makes a bunch of diff sizes and ch counts.. {you can always go with 1 four channal amp and put switches on the speaker leads to tun on and off what speakers you didnt want to use... there are a ton of ways to do this...
