Robert Shafer
What would any of you suggest for a second system for the house. I have a Yamaha 4600 receiver in the main room, but I'd like to do simple surround in the back room as well. What do you suggest?
Bob
N
Nick250
Bob
Are you asking about receivers or speaker packages? Budget?
Nick
Robert Shafer
I'm looking for receiver and speaker packages. I have a second quality dvd player and may move to bluray or hd dvd when the choice becomes clearer.
Bob
Robert Shafer
Medium sized room - open architecture. No hi def there yet; but probably in the future. Somewhat tight budget - but want the expandability of good quality if possible.
Need a DOLLAR value for the budget....so we know if we're talking HTiB or if it will be a pieced together system. The difference between a $500 and $1500 system is pretty significant.
Robert Shafer
I could go 1000 to 1500 if the difference was very great. No chance on going higher
Bob
Bee-Man
Two sets....each great value at there respective prices....
** Hsu Research Ventriliquist with the VTF2-MK2 with a Yamaha RX-V559 for around US$1K plus cables, interconnects etc...
** SVS package with the Yamaha RX-V659 for probably around US$1.5K....I would get the 7.1 (its only a little more) with the sub upgrade and outside of a new receiver....look for a 'last months model' receiver with ~ 120W per channel....
Just my two cents....
