Sealed sub for PC audio using ACI SV10
alphaiii
Hey all,
I was browsing Madisound's site and saw they are selling the SV10 woofers that ACI used to use in their subs.
I was thinking about possibly using one for an INEXPENSIVE small sealed sub for a 2.1 PC music setup. According to the madisound site, a 0.7cuft gives an f3 around 40Hz...and this can be pushed into the lower 30's if using a plate amp with some low end boost.
I've never build a sub, or even modeled performance for that matter, so I wouldn't have a clue from the woofer's parameters if this driver would be any good for this application or not.
Thoughts and help would be much appreciated. As I alluded to above...keeping the budget down on this would be key, so I'd need to find a worthwhile and reasonably price plate amp. Do you think I could I keep total costs to around $200 and it still be worthwhile?
Thanks in advance.
Driver parameters: http://www.madisound.com/catalog/PDF/SV10Specs.pdf
