$600 is a decent budget. Check out Carada at the upper limit of your budget.
Otherwise, to save, you can spend considerably less with Focupix.
To save even more, you can go DIY. Jinjuku recently has done so, maybe he'll chime in if you express interest.
Lastly, you might consider what I will likely go for in the future. Seymour CenterStage XD fabric at only $13 per linear ft. Add a false wall. Hide all three LCR and subs behind it. Use three identical, vertically arrayed speakers for LCR, all at the same height. This gets you the best possible dialogue intelligibility, best possible panning, best possible acoustic match, improved center channel power handling, avoidance of midbass boosts from the floor, and having dialogue and all audio in general utterly locked on to the screen.
