scar audio 15in vxf d4 ported sub build concept
johnny45
johnny45
cab is to be made from layers of birch an mdf
driver choice wired to 2 ohms currently own (scar audio vxf 15in d4)
amp is crown xls 1502 775watts at 2ohms per ch
cab concept dims with driver at 4.5lt are to be 16in w by 26in h by 9in d = 2cft
outer 12in d by 22in w by 60in t
port lenght 86in l by 4in h by 9in d
with 6in flair
in winisd port m/s velosity
opt 1. without parometric eq at 25hz .q=1 by 6+db is 15.8m/s at 20hz
opt 2. with parometric eq at 25hz .q=1 by 6+db with 24 dB/octave (4th order)highpass at 16hz is 30m/s at 20hz
with opt 2 an the port size an length do you think id get port Chuffing
