Samsung UE55C8000 doesn't get along with my Denon AVR4311
JBong
Hi.
I currently have the following setup:
STB -> Denon AVR4311 -> Samsung UE55C8000
All connections are made through HDMI and I've enable the HDMI control option on the receiver for the STB signal, so I can pass it through the TV when the receiver is in standby. The problem happens precisely with this feature.
If I have the receiver, the STB and the TV on and I decide to turn off the receiver, no problem, I still get the STB signal to reach the TV.
If after that I turn on and off the STB, all works fine, signal is still sent to the TV.
However, if I turn off the TV, when I turn it back on, it looses the signal coming from the receiver. Let me give you an example: I've got the STB and the TV on with the receiver off, all working fine. If I leave the STB on and turn the TV off and on again, it received the STB signal for like 1 or 2 seconds and then goes black claiming it's receiving on signal...
So what might be happening to my TV?
Thanks.
