Sale: Behringer DEQ 2496 and DCX 2496
Docks
Both used in higher stereo, still very new.
Will sell each for $300, or both for $550.
Both units are very minty.
Audiophile quality (Uses balanced XLR, not noisy RCA cables)
Fantastic DAC's
Specs Below
ULTRA-DRIVE PRO DCX2496
Ultra High-Precision Digital 24-Bit/96 kHz Loudspeaker Management System
3 analog inputs (one suitable as digital stereo AES/EBU input) and 6 analog outputs for maximum flexibility
High-end 24-bit/96 kHz A/D and D/A converters for ultimate signal integrity and wide dynamic range (113 dB)
Integrated sample rate converter for easy connection of external digital signals with sampling rates from 32 to 96 kHz
Precise Dynamic EQs for level-dependent equalization and extremely musical Parametric EQs, selectable for all inputs and outputs
Several types of EQs (LP/BP/HP) for each input and output
"Zero"-attack Limiters on all output channels for optimal speaker protection
Four different mono and stereo output operating modes
Individual crossover filter types (Butterworth, Bessel and Linkwitz-Riley) with selectable roll-off characteristics from 6 to 48 dB/octave
Adjustable Delays for all inputs and outputs—allow manual or automatic correction for room temperature, phase and arrival time differences
Additional Sum signal derived from the A/B/C inputs offers a fourth internal input signal
Free ULTRADRIVE PRO software enables total control via PC through RS-232 and RS-485 interfaces (download at BEHRINGER: Home)
Link option via RS-485 network interface enables cascading of several ULTRADRIVE PROs
60 user-defined internal presets storable via PC software or on PCMCIA card
Servo-balanced, gold-plated XLR connectors for all inputs and outputs
Internal switch-mode power supply for maximum flexibility (100 - 240 V~), noise-free audio, superior transient response plus low power consumption for energy saving
High-quality components and exceptionally rugged construction ensure long life
ULTRACURVE PRO DEQ2496
Ultra-High Precision 24-Bit/96 kHz Equalizer, Analyzer, Feedback Destroyer and Mastering Processor
Ultra-high resolution 24-bit/96 kHz mastering processor featuring 32/40-bit floating-point DSP technology
Audiophile 24-bit/96 kHz A/D- and D/A converters offering 113 dB dynamic range
4 concurrently selectable EQ modules (31-band graphic EQ, 10-band parametric EQ, Feedback Destroyer plus 3 Dynamic EQs per stereo channel)
Ultra-high resolution 61-band real-time FFT analyzer with additional auto EQ function for room and loudspeaker equalization
Unique VPQ (Virtual Paragraphic EQ) option allows parametric control of graphic EQs
State-of-the-art compressor/expander with peak limiter per stereo channel, additional stereo imager and stereo delay for delay line applications
Multi-functional level meters (peak/RMS, VU and SPL meter with dBA/dBC weighting via RTA/Mic input)
64 user memories for complete setups and/or individual module configurations
Separate mic/line input with phantom power for RTA and Auto-EQ applications
Balanced inputs and servo-balanced outputs with gold-plated XLR connectors, stereo aux output, AES/EBU and S/PDIF inputs and outputs (XLR and optical)
Professional Wordclock input and MIDI connections for full remote control, preset dumps and system updates
Open architecture allowing future software updates via MIDI
"Planet Earth" switching power supply for maximum flexibility (100 - 240 V~), noise-free audio, superior transient response plus low power consumption for energy saving
DCX 2496
DEQ2496
annunaki
annunaki
Moderator
One can purchase the DCX for around $250 new when on sale, not sure if you were aware of this?
darien87
darien87
Yeah, Sweetwater sells the DEQ 2496 for about $300 new. I'd be interested in that one for a better price.
templemaners
I see the DEQ2496 for $229 and the DCX2496 for $254 on Amazon.com right now.
timoteo
timoteo
Yeah but guys, the ones he has are "MINTY", you just cant put a price on that!! :)
annunaki
annunaki
Moderator
Look everyone, the intent of my post was to help the OP be able to sell their gear a bit quicker. It was not to bash anyone for what they are asking for their equipment.
Thanks!
timoteo
timoteo
A good ol' jokey joke is always fun & was needed to lighten things up!! I will not appologize for my quick wit & dangerous good looks!!! :)
Im sure the OP will do some research, adjust his asking price if he deems so & have no problem selling those fine pieces of equipment in no time.
