jcsprankle said:
So just so I'm straight in this, there will be three connections from my DVD player to my receiver/TV:
1) 5.1 channel output (6 RCA) for SACD and DVD-A
2) Optical digital output for DVD movie audio playback
3) Video connection for DVD movies and DVD-A video
Is this right?
If so, I have a follow-up question. I was reading the online version of the Denon 2910 manual and came across the following:
Does this mean that with the Denon, I shouldn't use both 5.1 and optical outputs at the same time? This sounds like a serious limitation...
Yes, you will use the
1) 6 analog cables from your player to receiver for sacd/dvd-a;
2) optical cable (toslink) from your player to receiver for movie (and cd) playback;
3) video connection from player to tv for video playback (component is best, the s-video, composite is worst). Additionally, there is no need to run the video through the receiver unless you have multiple players...so just run it directly from player to tv.
4) You will require a second cable from receiver to tv if you wish to see the on screen display/setup for your receiver. Since this is only for setup/tweaking, and not video playback, s video or composite cable is fine.
5) You can not use both the 6 analog and the toslink simultaneously. One is for sacd/dvd-a, the other for movie audio/cd. You can only play one disk at a time.
6) You will have to set the parameters for the combined 6 analog/1 toslink in your dvd setup. It's not that complicated. Read the manual, and set it up
