MDS
So in order for DD-EX to function, there must be 2 front, 1 center, 2 rear surround, 1 rear center, and a sub, is this what DD-EX is...6.1? So if I only have a 5.1 system the amp should detect this?
If you tell the receiver you only have 5.1 speakers - whether it figured that out itself via auto-setup or you manually go into the speaker setup menu and select Yes/On for the speakers that are actually connected - then the DD-EX decoder will not be available, nor will PLIIx. You can't use a decoder that creates more channels than you have speakers.
So if I am watching a movie and I select the option for DD-EX (in the sound setup of the DVD), is it outputting that to the receiver but the receiver knows that configuration does not exist so it is smart enough to use DPL II in place?
The 6th channel is matrixed into the surround channels so the receiver will most likely use the straight DD decoder. If you had the surround back speaker connected and told the receiver surround back = Yes then you could press the surround button to change to the DD-EX decoder or it would automatically select it depending on the settings I described earlier (auto, always, never).
PLII converts 2 channel analog or digital signals to 5.1. If you select the DD-EX track from the DVD, it's already 5.1 (the 6th channel is simply not extracted) so PLII has nothing to do and it should use the straight DD decoder.
JWhite
JWhite
Ok so I reconnected the rear surround back to the original configuration and connected the center channel. Now the Center and the Rear are showing REV. The weird thing is if I reverse the connectors on the opposite rear speaker, the rears are fine. I have not done that since I reconnected everything correctly along with the center. I am have no idea what the heck is going on, I think I am about to lose it :eek:
I really hope the amp is not defective... or the speaker cable, but I have no idea what to do...maybe having the type of rears I have explains that, but what about the center reporting REV...
MDS
Ignore the phase warning, it is wrong more often than not.
