RXV1500 problem, Yamaha going downhill?
big deal
Yesterday I powered up my receiver and about 3 seconds after the display lights up, instead of coming out of protect mode it shuts itself off. I looked around a bit and found that it is a known issue with this model, although I'm not sure how common it is. I am past the warranty period and I am wondering if anyone else has had this issue, and how much it cost them to have it repaired? If its going to be more than a few hundred bucks, this might be an excuse to upgrade to something with HDMI since I am looking into a TV upgrade and bluray player soon as well.
On a related note, is it just my bad luck or has Yamaha really slipped in terms of quality control and durability the last few years? I have been buying Yamaha gear for years and until the last 5 years or so I have had no issues whatsoever. This is my 4th Yamaha receiver and I really expected to get more than 3 years out of it. Every other one lasted until I upgraded, and at least one of them is still in daily use at my brother's house after about 8 years. The Yamaha DVD player I bought a couple years back has had numerous problems as well (S550). I bought it for the divx playback capabilities, being one of the only ones around at the time but as it turns out it was a feature I ended up using all of 3 or 4 times. This unit freezes up randomly and has to be unplugged to reset it, even after a firmware upgrade. Anyways, am I just unlucky or is Yamaha just not as dependable anymore? Opinions would be appreciated, if I am going to have to replace the receiver, I want something more dependable but in the same price range, if such a thing exists anymore. I have been out of touch with the AV scene for a couple years since getting married. What is good these days? I would prefer to stay away from brands mass producing for big box stores from now on.
-John
Nomo
Nomo
I assume you've checked the wiring to rule out that possiblity?
I really don't feel as if Yamaha's quality in receivers has slipped at all. I'm on my second one.
As far as DVD players; I have one and I'm not completely happy with it. But as far a their receivers go... After looking at Onkyo, Pioneer, etc.. I decided to stick with Yamaha with my recent upgrade. The old one is a 1500. New one 1800.
Oh yeah, ignore the avatar, don't mean a thing.;)
big deal
Its not a wiring issue, same thing happens with nothing but the power cord attached and it doesn't matter what mode or input its set to.
-John
B3Nut
Time for it to hit a tech's bench. If it doesn't come out of protect it could mean an output transistor has shorted internally. BTW, if it's the outputs this isn't so much a Yamaha issue as everyone buys output transistors from the same small pool of vendors (Sanken, Toshiba, etc.) Sometimes semiconductors "pack up" for no apparent reason, it's rare, but it does happen and is a pain in the arse when it does.
F
fmw
How can a single isolated instance be any indication of the quality control of a company's entire quality control?
GlocksRock
GlocksRock
Haven't had any issues out of my current RX-V1800, or my old RX-V1600 when I had it.
ParadigmDawg
ParadigmDawg
I was 15 years deep in my last Yammy and 1.5 years into this one and have no issues.
big deal
If you read further into my post, I have had problems with the 1500 as well as the DVD player I bought, both in the last 3 years. Everything Yamaha I have owned previous to that has been bulletproof, hence the title of the thread. These are just my personal experiences, but after doing some research I found numerous accounts of the same issues with the same models. That, to me sounds like either quality control, using low grade components or poor engineering. But I guess it could be just coincidence.
-John
Hi Ho
Hi Ho
We sell and service Yamaha gear at work and there has been no increase in the number of units in for service, which is very low. The only time I've encountered a similar problem was with an RX-V2500 that was in a poorly vented cabinet and when the customer turned everything on (including zone 2) it shut off instantly because the zone 2 amp was turned all the way up.
As far as Yamaha DVD players go, that's a little bit different. Many of their players are made by Phillips and they have not proven to be reliable.
big deal
Thats good to hear, I have never used zone2 on my 1500, and the cabinet has 5 inches of clearance above the unit and is open in front and back so I doubt its an overheating issue. I have always powered my fronts with another amp, so the strain on the amp section of the 1500 should be pretty low even when running in 7 ch modes. If it is the output transistors as B3Nut suggested, any idea on the repair cost?
-John
Bryguy
Bryguy
My 1400 is still running strong (I hope) and no problems since its original purchase.
Bryguy
