You've got a few choices.
1) Turn it down.
2) Add an external amp
3) Set the receiver to 6 ohm instead of 8 ohm. What you are doing here is lowering the output power by choking off the power supply, but it will likely cure your shut down problem.
4) Allow more breathing room above and to the sides of the unit, or add a computer fan above it running off of one of thw switched outlets through a 12V converter.
5) get higher impedence (8 ohm) speakers.
I would recommend #4 and #2. You can pick up a good used Carver or NAD on ebay for $200 if you shop around.
