J,
I've searched high and wide for speakers to go with your setup. I know you are looking for somethign to go with your sleek tv. Unfortunately, nothing in the line of wall mounted speakers really surpasses the Yamaha's you've listed. They feature 4-4" drivers (not my favorite, but I'm betting they sound better than 1-5" driver). I was going to refer you to some NHT's or Paradigm bookshelves, but the bass drivers aren't going to give you much more bass than the Yamaha system is. Furthermore, the Yammy system features a 6.1 setup. Trying to find a good 6.1 setup is almost impossible in the $1000 price range. I like the BIC systems, but doubt it will look, or sound better than the Yamaha. Heck, even Athena's new line of speakers looks like that Yamaha system. They may have something there, with HT relying on voice and bass more than musical taste, you may be fine with that system. Try it. You can always return it. When you have to mount speakers on the walls, it really limits you to size. Compare the Yamaha with the new Athena. The Athena's you've listed are great, but they won't look as spectacular mounted to the wall as opposed to sitting on speaker stands. I would definitely get the supplied sub in a corner to extract as much bass as you can from it. It wont shake the house down, but at least with the right placement, will make up for the puny 4" woofers.
