can someone with the yamaha 2500 please tell me if you can use the REC OUT function will let you select the front input as an output? I looked online at the manual, but its not exactly clear...
I hook up my GL1 or XL1 sometimes to convert old VHS to miniDV (and then make DVDs on the PC, etc)
Is it possible to switch the REC OUT from either the front panel or from the GUI so that i could route my signal from my VCR1/2 and out to the front inputs, so i dont have to climb in the back and hook up or have any ugly extensions dangling from the back in the front for when i do hook up the camera?
muchos gracias!
