<font color='#000000'>In the manual setup procedure there is one item that the system will accept during setup but will not retain in the memory. Immediately after the setup I can scroll through the program and the change will appear as I made it. However, if I close out the setup and play a DVD (or whatever) and then return to the setup menu the item has returned to its original state before I made the change!
The culprit is the Front Speakers and the menu choices are LARGE or SMALL. My choice is (arrrow pointing to) always SMALL but as I mentioned above something consistently reverts the selection back to LARGE. (For any of you that might have the Yamaha 2400 this is on p.49 of the manual.) Don't know if these other items are relevant but here is my setup:
Parameter menu is set 'Set Menu'/Room Size 'M'/Subwoofer 'Yes'/Presence 'No'/Number of Speakers '7' and then I select 'Set' on the next menu followed by a successful speaker test.
Speaker Set: SOUND
Center, Front Speakers, Surround Left & Right, Surround Back Left & Right, all set to 'SMALL'. Presence speakers to 'None'
LFE Bass Output set to 'BOTH' and the Crossover is set to 80Hz. ('BOTH' meaning the Front L& R and Sub is used).
I've done this manual set up at least 25 or 30 times and still cannot figure out the prob. Although a couple of the instructions in the manual were vague at first, I've precisely followed the written procedures.
Don't know if there's any conflict in the setup I've chosen; would appreciate any help that can be offered.
-GeorgeM</font>
