K
Kilwox
<font color='#000000'>I bought an RX-V2400 just before Christmas, and after a couple of months of use, the remote stopped working. &nbsp;Literally none of the buttons would send any command, and the little LCD on the remote didn't show any input.
I returned the remote to my dealer, and they gave me theirs from the floor model. &nbsp;It worked for a couple fo months and now the same problem.
I'm wondering if anybody else has had this problem. Is it something Yamaha should hear about?</font>
W
wealreadyhaveamember
<font color='#000000'>I had the same problem. &nbsp;My remote worked for three months then quit on me. &nbsp;I changed the batteries. &nbsp;All is good. &nbsp;Perhaps you did the same, but sometimes its the simplest things that get overlooked.</font>
K
Kilwox
<font color='#000000'>Batteries are definately a good suggestion, which I did try. &nbsp;Thanks for pointing out the obcious though. &nbsp;Important details. &nbsp;My dealer thought of that too, but this seems to be bigger for soem reason...</font>
G
Guest
Guest
<font color='#000000'>Have you tried reseting the remote to its default?</font>
K
Kilwox
<font color='#000000'>Thanks for the advice Ross. &nbsp;I'll try it if it still acts up after it comes back from the dealer. &nbsp;I never thought it could be a command that I entered into it.</font>
