RX-V2400: How do you turn zone2/3 light off?
E
Electone
I can't get the Zone 2/3 red indicator to turn off on my display. Is there a way to do this?
ruadmaa
Turning off zone 2/3
If the 2400 works the same as the 1400, press the button labled amp on your remote and then the up or down select button until you see zone 2 then press the standby button, this will turn off zone 2, do the same for zone 3.
Z
zumbo
That is correct. If you power up with the power on the receiver, it will turn the zones back on. So always power the unit up with the remote.
E
Electone
The 2400 does not have an "amp" button on the remote. There is a "system power" button and "standby". Flipping through the source select buttons, there is no zone2 or zone3 options.
Hmmmmm......
Z
zumbo
Your remote is different than mine. Information is in your manual. Read page 72-74.
E
Electone
The manual is not exactly user friendly, but I have figured it out. You actually have to go into "learn" mode first to be able to do this. After you do this, the Zone 2&3 selections become available on the remote and you are able to send them into stand-by mode.
Thanks for the help guys.
Z
zumbo
Strange. It was a pain to figure mine out also. Glad you found it! :)
E
Electone
You go into "learn" mode by pushing in the little button at the top with the tip of a pencil or pen. Buy selecting this mode, you are now able to toggle through the selections on the remote's little display. This is where the Zone 2 and 3 selection finally become available. Hit learn again, and now you can send the zones into standby mode.
puertorro
I tried to turn off the zone in my 2500 but it doesn't work. I also toggled like you said but theres no zone 2 or 3 in the display. Any hint? :confused:
Z
zyepod
Yes... It does work... I turned mine off last night... Take it slow and pay attention to what the manual says... It took me several tries...
E
Electone
It may be a different process in the 2500 than in the 2400. You might have to consult the <gulp> owners manual...
G
Grubert
I just got my 2500 and thanks to you I could switch the zones off. Great job!
