Russ Andrews Expensive Kettles leads Fall Foul Again of The ASA
steevo
It seems that the ASA didnt believe Russ andrew ridiculous claims about mains
calbe filtering out RF and certainly didnt beleive the research paper he has on his website about the subject.
Thats what happens when you try pull the wool over peoples eyes which regard to magical scientific and engineering propeties, you get found out the be a fraud.
Check out the the links.
http://www.theregister.co.uk/2011/01/13/russ_accessories/
http://www.asa.org.uk/ASA-action/Adjudications/2011/1/Russ-Andrews-Accessories-Ltd/TF_ADJ_49597.aspx
BMXTRIX
BMXTRIX
Now we just need to rid ourselves of silly product from 1,000 other manufacturers and sanity may yet prevail.
I'm not counting on it.
Still every little bit helps.
jinjuku
jinjuku
Moderator
I have to go look to see if he still sells cable lifts and what problems they solve.
digicidal
digicidal
I'm sure he does, after all: "Pure metals love to ring. They do so sideways and also along their lengths..." I'll keep the source of this quiet as it's already well covered in another thread... but it's actual ad copy used in a loudspeaker ad.
It would only stand to reason that using lifts would help keep this from happening, since if ringing wires in a speaker cabinet are a problem - the ones lying on the ground should be even more "endangered".
EDIT: Also of note is this photo... which clearly shows the advantages to using them on your power cords as well as on your speaker cables. :)
Now to have one of those ASA boards here in the US of A:D
