C'mon guys, we're talking about a live-sound PA here, and using low-end equipment to boot!
Clancy, I had a gig once where due to an equipment failure I had to run unbalanced audio at least that distance between the mixer and the amps on the stage. It worked fine. Just keep in mind that with an unbalanced signal, your cable - or rather how well you cable is shielded - will make or break you, as far as pickinig up noise is concerned. Coax is about as good as it gets as far as shielding goes because it has both a foil and braided shield. I'd go with RG-6 and use F-to-RCA adaptors.
Regards,
Wayne A. Pflughaupt
