Rumble bass on sub. Please Help!
yannaros
yannaros
I am trying to configure the best sound positions for my REL T3 Sub woofer.
I try to pair them with a Magnepan MG12 speakers.
They give me though some rumble and a pop up noise in my ears.
Iwas wondering if the reason is the phase the level or the crossover of the sub.
I would appreciate any help
Thank you
jamie2112
How are you running your speakers? From the sub or from an AVR? The sub should be out of the sub output and run your speakers from the main L&R out on your reciever.Set your speakers on "small" on your speaker settings on your AVR.Set the crossover on your sub to 80hz and you should be cool...
yannaros
yannaros
Thanks for your response jamie2112
My subwoofer is not connected to the speakers.
Instead its connected directly to my power amp.
Its a special cable from REL that connects the sub to the amp.
Also my speaker's response are 45-22kHz ±3dB
Am I supposed to set the crossover at 45hz? or the 80hz as you say its a common solution?
Unfortunately Jamie you are dealing with a British sub, and us Brits are a contrary lot, especially when it comes to bass management.
Most British speaker manufacturers including B & W disagree with just about everything Lucas labs have to say about bass management. For the record I basically agree with their point of view.
British speaker designers are aghast that someone would consider inserting a crude second order receiver crossover at 80 Hz, or any point above the natural roll off of their speakers. For all but their very smallest offerings, they want the their speakers set to large.
To that end REL want there speakers connected to the speaker outputs and the LFE output. This sub is designed to have the speakers set to large, and the sub crossover set low, in the OP's case probably start at around 40 Hz and advance volume slowly.
The next problem is that the OP has planar dipolar speakers. Subs are a very difficult match for speakers like that. The sub can be in phase with the front of his speakers or the rears but not both. So either the front or back radiation will cancel the sub output.
Peter Walker only ever sanctioned the di-polar Gradient sub for use with his EL 64 electrostatics.
http://www.hometheatermag.com/subwoofers/108rel/
http://www.rel.net/index2.htm
markw
That rumble and pop seem to be related to the power amp driving the sub. Either that, or your source* is generating them but I doubt that's the case.
80 Hz is not an unrealistic figure for those speakers. I run 1.6's and set the crossover between 55 - 60 Hz and the 12's are smaller.
*This is asuming you're using a LFE output.
yannaros
yannaros
TLSguy you were very helpful , especially at:
(This sub is designed to have the speakers set to large, and the sub crossover set low, in the OP's case probably start at around 40 Hz and advance volume slowly.)
It really helped a bit but its not perfect yet.
One question...When you say --This sub is designed to have the speakers set to large--what do you mean?
Thanks for the links too.
I hope that post stays alive for more discussion
yannaros
yannaros
I really consider the reason for the rumble to be related to the power of the amp
PS: markw I dont use an a LFE output.
Thank you both guys
Thank you both guys
Now lets back up a bit? What is your set up? This is important as if you are not using a multichannel AV receiver or pre pro, then you won't have a large setting.
Now in AV systems, there is an adjustable crossover in the receiver. This can be set to send all of the input to the speakers, and have the 0.1 low frequency effect channel sent to the sub below the frequency you set it at.
This is having your speakers set to large.
Or you can set it you can set it such that the speakers are rolled off at 12 db per octave (second order) and the lower frequencies and the LFE channel sent to the sub.
Now your sub is not set up like other subs discussed on these forums. When using this sub, you have to use it with either a standard two channel non AVR system, or if you use it with an AVR system, the speakers must be set to large. It is not an option to set them to small with this sub.
The REL sub is deigned to receive the speaker output at least from the right and left mains. This way the REL crossover can be adjusted to augment the LF of the mains in a subtle fashion. The LFE output of an AVR or prepro system can be captured as well from the LFE output.
If you were using monople speakers I would recommend setting the REL crossover at 90 Hz which is the F3 (45 Hz) of your speakers times 2. However because of the phasing issue of dipoles and a monopole sub, I would recommend setting the REL crossover at 40 to 50 Hz range. Try experimenting.
Now there is very little musical material in the sub 45 Hz region, so most of the time your sub should be completely silent. It will occasionally sound and gently augment your main speakers. If you do not understand this you will turn it up far too loud and get the problem you are posting about. This is very likely going to do serious damage to your sub. The popping is the voice coil of the sub driver bottoming.
I would recommend you get a test disc of test tones, and an spl meter, and then set you sub for the smoothest in room response as you cut in the sub.
I did this with the B & W sub for my friends B & W 800D set up. The sub is silent most of the time.
Basically subs are very much a second best solution from an acoustic point of view, but avoid people having huge speakers in their homes.
For my main speakers I do not use a sub, but truly full range speakers. However, I have to be prepared to devote a lot of real estate to speakers.
I have this problem with my other system.
This is a very good two channel system and I suspect similar to what you have. Most of the time the subs are silent, but if someone hit a big bass drum, or a deep organ pedal sounds they come to life. However the power delivered from the amps driving them is low.
I can't stress enough that unless you understand this you will turn the REL up too loud.
If you would post about your set up and what music you want to listen to then it will help me to advise you further.
Big ported subs are a truly American animal, that if used in most European homes would get the owners arrested and their gear confiscated.
Most of the time owners have these subs set too high, and the subs have a high Qtc, and it smears over everything in a most unnatural fashion, at least for classical music. Pop, rock and movies are another matter. For that music, and a lot of sound effects, there is no real point of reference, or if their is it is not knowable by the listener.
However, a movie played through my system actually aces the big sub brigade. It still has the power and authority to shake the floor and hit you in the chest, but remains balanced, with very natural speech, and the sounds of every day life are so accurate, it adds a huge dimension to the movie experience.
My strong suspicion is that because of the speakers you have chosen you are not in the bloated bass brigade.
Your post seems to have got deleted somehow, so here it is: -
I took some pictures of my system and here I am
My set up is:
Preamp: Rotel RC1082 (but is upgraded to the new one that Rotel has)
Power amp: Rotel RB1080 2x200W
Tuner: Rotel RT1080
DVD: Rotel RDV1045
Power Conditioner: Rotel RLC1040
Subwoofer: REL T3
Interconnects: Straightwire Encore 2
Speaker cables: Straightwire Encore 2
My RELT3 Sub is connected as shown in the picture with a special cable Neutrik Speakon high-level input for direct connection to amplifier. (Its the blue cable on the photo) and its placed behind the left speaker with the back panel facing the side wall.
I set the crossover around 40-50Hz as you recommended and I am increasing a little by little the volume.
The volume and the crossover knob are divided in 40 clicks so I calculated that 40-50 Hz should be somewhere there.
The phase is at 180° because at 0° it gives me a lot of bass, deeper that my ear pops (Oh god!)
After I put the spikes on the sub the volume of the sub reduced a bit.
I listen to a variety of music but mostly new age, electronic jazz, progressive and some classical music.
I hope that helps.
Thank you
You need to set your phase to 0 degrees. Always set the phase to the setting that gives the greatest output, otherwise your speakers will fight each other and contribute to the sub driver bottoming. Just use a lower volume setting so the bass is not too loud.
Your whole problem has been wrong phase and turning the sub up too high.
yannaros
yannaros
My set up is:
Tuner: Rotel RT1080
DVD: Rotel RDV1045
Subwoofer: REL T3
I hope that helps.
Thank you
I am really sorry Mark
I was trying to upload images.
Please allow me once more my message with images
jostenmeat
Nice gear! Your Rotel fanboyism will be sure to please TLS guy.
My set up is:
Tuner: Rotel RT1080
DVD: Rotel RDV1045
Subwoofer: REL T3
I hope that helps.
Thank you
Nice pictures of your gear. I bet that sounds nice. Your pre amp does not have an LFE output, so your connections are correct.
As stated you need to set phase for maximum output, and according to your observation that is 0 degrees. You will need to turn the sub down further after you make that change.
One other observation from the pictures, I think your Magenpans are too close to the wall behind them, they need pulling out into the room a little more. That is one of the problems with planar speakers, they have to be well away from room boundaries, especially the ones behind them. If you can't pull them out then good acoustic absorbing panels behind them might help.
yannaros
yannaros
Phase now is at 0
Volume on the sub is low and keep experimenting
I cant put though the speakers out of the wall more , the space is limited.
The total sound is way way improved. ;)
Thank you Mark you've been very helpful
I hope that post help others with a similar problem
