In-Wall installations are getting more popular every day with the arrival of new audio formats like Auro 3D & Atmos. The W26 In-Wall speaker from RSL Speaker Systems is one of many options. The W26 is an excellent choice for people who wish to conceal some or even all speakers in their home-theater system. It has the versatility to be used in all positions along with a subwoofer, but I prefer it as surround channel. As with all RSL speakers it can be mixed-and-matched with any of their home theater speakers like the CG4, CG24, and the C34. Of course, you can also use it for stereo and for multi-room installations. If you are looking for some good in-wall speakers to get the job done without breaking your pockets, I suggest you give this babies a look. Do we have any owners here? Tell us what you think about them!
FEATURES:
- (1) 6-½” woofer with polypropylene cone and a 7/8” soft dome tweeter.
- The tweeter can be swiveled.
- The W26 employs higher quality crossover parts than most in-wall speakers for clearer sound.
- Grills can be painted to match your wall color.
SPECIFICATIONS:
- 6-1/2″ woofer.
- 7/8″ soft dome tweeter.
- Overall Dimensions: Length: 12 1/8″ Width: 8 3/4″ Depth: 3 3/8″.
- Mounting Hole: Length: 10 3/4″ Width: 7 3/8″ Depth: 2 7/8″(allowing for wall thickness).
- Impedance: 8 ohms
- Crossover Frequency: 2,500 Hz at 6 db/octave.
- Weight: 3-1/4 lbs.
Price: $169.95 /pair
