After getting the new meter, I measure 7 VAC between neutral and earth.
neutral and phase give me 240 VAC and phase and earth 233, which I believe means that some equipt. in my home puts 7 VAC back on the earthing.
Anyway, I moved my amp to the otherside of the house to dismantle it again and cleaned the screwed connection between pcb and chasis.
Doing the checks with a small speaker gave me possitive results.
But now the trouble start. Bringing back the amp to the cupboard, hooking all speakers up, checken and all seems OK.
After hooking up the interlinks, there the buzz came back again.
Took amp out and put it on the floor. hooked up mains from other side of the room, hooked up one speaker and all silent. After plugging in one interlinked (well shielded) and not plugged in on the other side, buzzing starts.
moving the loose and around, up and down and over the floor had influence on the buzzing.
Then the following came into my mind, there is on that side of the house a high voltage power line hanging above the ground less than 120 feet away.
It really looks like the interlink functions like an antenna which picks up the interference, which could explain the cause. I also tried different interlinks all reacting the same.
Meanwhile I also tried the setup outside all same same, but as soon as I move the loose end of the interlink behind the amp, so the amp is in between high power lines and interlink, buzz stops.
Maybe put a metal plate against the wall!?
all other equipment againt same wall like sat receiver, TV or integrated amp are working fine.
