Question...
I'm wondering how affective simple foam type panels will be along the walls of my den/home theatre? The room is approx. 16 x 9, rectangular...a bass trap nightmare! I have limited space for treatment (plus, to be honest, I don't want the whole room covered in foam like a rec'd studio...it is my house after all!) I've been in contact with a couple manufacturers about treatment options (one from this site actually) and they're fairly helpful. The problem is, I think they probably oversell you on panels & solutions.
Will one gain (or lose actually) any significant audio properties from hanging a number of panels on all the walls? Assuming the proper foam is used, and each panel is approx 2 X 4?
What are my options?
