Thanks for all your replies. I have tried moving subs (only by ear though) and it didn't really seem to help. If I stand anywhere in the room and clap my hands, I get a "tinge" echoing in the room. Also, any time I balance my channel leves I always hear (kaaaaaaaa, kssssssss, koooooo, etc) meaning althought the speakers are from the same manufacturer across the front (same model in some cases) they all sound differently, which has to be attributed to the room. I am looking at the Auralex foam treatments to put in the tri-corners and to kill the first order reflections from the front speakers. The only bad thing with this is that I have DVD racks built into one of my side walls (included pics in the post) and don't know how I can make the panels look very good...I'm open to any suggestions! Also, with my bipolar surround and surround back speakers do I want to kill any reflections from these as I know normally you thrive on the reflections from speakers like these? If I use a mirror on the ceiling, I can see the first order reflections in a straight line across the ceiling, which makes since as the speakers are in a striaght line across the floor. I am also looking at a few EQs from Rane and Audio Control to smooth out what the treatments don't grab. I figure as opposed to upgrading another component (speakers, etc) I would like to start with the room and don't mind spending ~$1000 (for both EQ and treatments) if it will make a large difference in the sound.
