Rookie questions. Please Help
alain1020
First, I'd like to say hello to all. I have been lurking in this and other A/V sites and never new there was so much to learn about home theater. Okay here are my rookie questions.
1) I have an old Techniques Recvr SA-GX470 and wanted to purchase a B&W CC6 center channel but the wire connections don't seem to be compatible with my old reciever. What can I do to fix the problem? I'm eventually planning to get a new reciever but financially not ready yet so yes I'd like to continue to use the old.
2) For those who have experienced the CC6 center channel personally, how would you compare it to a larger driver such as a Klipsch c-3 which have 6.5 inch drivers. Do those smaller CC6 drivers have a realistic tone when it comes to movie dialogues and concerts?
3) What do you advanced audiophytes feel about using different brand speakers (center channel, front speakers, subwoofer) when it comes to creating a system. Or do you feel it necessary to keep the same line. Do you actually lose quality or just personal preference?
Thanks to all in advance....
Adam
Adam
Welcome to the forum, and happy holidays!
I'll give your questions a try:
Would you help us out and let us know what the connections are on the receiver and on the speaker? I'll look around, but it's sometimes difficult to find connection info on older receivers.
Sorry, I haven't heard it, so I can't help here.
The most important speakers to match are the fronts and the center, and this is not just matching brand - you'd want to get speakers that the manufacturer recommends for timbre matching. This is because you want the sound qualities to be very similar as sound moves from right to center to left. For example, if a motorcycle in a movie or show moves from right to left across the screen, you don't want it to sound like a Harley in the right speaker, a moped in the center speaker, and then a Harley again in the left speaker. The rear speakers aren't as important to match to the front three, and there is no reason to match the brand of the subwoofer to the brand of the other speakers.
Nomo
Nomo
That receiver is only 2 channel, is it not?
To run anything beyond a right and a left channel you will need a receiver with connections for a center channel.
Look for one that has at least 5.1 channels. This gives you the ability to run a center along with surrounds and a sub.
Rickster71
Rickster71
Nomo, you're right, it only plays in stereo.
