Roll your own speakers
WndrBr3d
WndrBr3d
I'm going to be building my own custom cabinets and I'm looking for a good website where I can purchase cross-overs and good quality speakers.
Any help would be appreciated! :)
Reorx
Parts express seems to have alot of parts and pieces. I've known alot of people to build speakers using them.
If you haven't built speakers previously, I'd recommend buying a kit or at least start by buying some books. Something like The Loudspeaker Design Cookbook (6th ed currently) might be well worth your time if you are serious about doing DIY. Building your own speakers is a great experience, though it is not quite as simple as it may seem to make a speaker sound even moderately "right". There are a lot of variables and design considerations that need to be made before you start. Sealed or vented? 2way, 3way, more? What size room? How deep do you want them to play? etc... Then when you start looking at components, you have to select drivers that will blend well with each other and select a type of x-over and locate one with the correct x-over points (or make one tailored to your desired x-over points) that will work with those particular drivers'. Then there is cabinet volume/tuning, driver alignment (phase) relative to eachother, driver position (which will affect response greatly), etc... This part is almost impossible to "guesstimate" without proper equipment to measure response.
Buliding a kit has taken this guesswork out of your equation unless you are looking to learn how to design speakers. My current speakers are DIY kits and I've built subs previously with excellent results. I bought my speakers built, but I rebuilt them from the ground up basically, with upgrades offered by the manufacturer; I replaced almost every component in them.
I don't know if that helps or not, but there are plenty of places to find the right parts if you're interested. Might check in the DIY forum here too.
Funny avatar :)
mulester7
mulester7
.....WndrBr3d....talk to the guys at this place.....ask them about possibly a combination of Peerless and Scanspeak if you are considering 2-way.....
http://www.madisound.com/
Spiffyfast
Spiffyfast
I've checkout some stuff at madisound too, looks like they have some great kits, I had thought about building one of their sub kits.
I buy a LOT of stuff from PE. Great service, good stuff. I haven't tried any of their kits yet though. Madisound is great too.
9
9f9c7z
Somewhere here on the Audioholics webpages is a tech note about someone that built their own loudspeakers. Don’t remember who, just remember reading it here. Top quality speakers popped out the other end, as I recall. It’s definitely worth reading thru. You may want to look for it, or maybe someone else knows where it is on Audioholics.
philh
I built the 12" sub kit! It F* Rocks. Unfortunately my cheap sub amp (bought elsewhere) recently failed and I put a poll in the amps section about replacement amps
JeffB
Bob Brines speakers
You might want to look here.
Bob Brines offers his speakers in various degrees of completeness. From just the plans on up to fully built speakers.
http://www.geocities.com/rbrines1/Products.html
A lot of people seem to like the FT-1600 MkII.
You can ask JLM on audiocircle.com about the FTA-2000.
I have not heard either myself, just seen them mentioned a lot.
