Rockwell Jaw Horse plus clamp $159
jinjuku
jinjuku
Moderator
Vid showing the plywood clamp
This allows you to handle full sheets of ply...
jinjuku
jinjuku
Moderator
Rockwell Jawhorse plus $55 drill press = Portable drill press workstation.
The jawhorse is a beast. Really easy to use and I can pick the entire thing up by the drill press and nothing is going to move:D
