Dear all
After reading (ages ago) the paper
Subwoofer Calibration Using Rives Audio Test CD 2 here, I duly went ahead and ordered the CD. After all, Audioholics consistently gives, I would say, pretty solid/dependable advice.
However, after using the CD's tones with the Radioshack SPL meter and posting results on this site, it was quickly made clear to me that my readings were effectively useless. Why? Because at low frequencies, 1/3 octave measurements are far too coarse.
Since then, I have found that an alternative method of downloading (for free) and using
ETF is far superior. It's not a particularly difficult program to use, and the cost of the few cables and couple of adapters required to take the necessary measurements wouldn't, I feel, be appreciably more expensive than buying the Rives CD.
So why do people keep recommending the CD when there's a much better way to take the measurements?
Regards
