PLHART,
I beg to disagree about the Radio Shack meter. It is a standard reference meter for calibrating SPL on "the Dub Stage". It is accurate for checking pink noise for speaker calibration. I do agree that it is NOT to be used for frequency room EQ broadband calibration. You need an RTA with a calibrated Mic.
My room
www.thedubstage.com
has been calibrated by Dolby Labs for the standard "X curve" which is flat to aprox. 2K then proceeds down 3db per octave. There is also a modified "X curve" for smaller rooms (which are what nearly all your readers have) which is flat to 2K then down 1.5 per octave. Some take it flat to 4k then do 3db per octave.This is probaby a better set up for most people.
Here is another link that your readers may find interesting. It is about "Room Calibration for Film and TV Mixing". It has some very interesting reading if your readers want to understand better what the Pro's do for standard calibration. The link is:
http://duc.digidesign.com/showflat.php?Cat=&Board=UBB6&Number=529464&page=0&view=collapsed&sb=5&o=31&fpart=1
A very common mistake by Audiophiles is to have a very flat frequency response using uncalibrated Mics and test equipment thinking that is what it should sound like.
It’s only after mixing in a calibrated “dub stage’ does one know what the original mix should sound like. Unfortunately many if not most of the “Home Theater” manufactures don’t have a clue what a “Theater” should sound like!
Thank you for letting me educate your Forum readers in hope they can enjoy great sounding “Home Theater” the way we do when we work or should I say play while we mix!
Marti D. Humphrey C.A.S.
Re-Recording Mixer
www.thedubstage.com
