I recently got an old EQ, a second sub and the test CD in that order spaced out across a couple of months. I'm out of work right now so I have time to play around with this while the wife is working. Room treatments will have to wait.
My first concern is the positioning of the RS SPL meter. Rives says the opening of the meter should face forward but it's not critical. Then why tell me to face it forward? They say to use 1k Hz @ 80dB as a reference. I used 500 Hz @ 70dB as 1k Hz on the R channel had a nasty dip and 80 dB would never go unnoticed by my neighbors. Does that sound okay?
The first thing I did was calibrate my channel levels and level matched the three sources I use (DVD, CD and 6 Channel). I use my receiver's L&R pre-outs to go into the EQ and then a 2 Channel amp. I am EQ'ing the speakers, not the subs.
A search revealed a post where Mtrycrafts suggested that the L&R channels be plotted and adjusted for separately. I did this but had both subs hooked up. Later today I'll try to plot just the subs separately and the entire system as a whole. How should I be approaching the plotting and adjustment process for 1 individual channel with 2 subs? I think that my previous method must be flawed and is responsible for a nasty 50 Hz spike. So far it's been good fun playing with this but I'm hoping to get some tips that take me to the next level (which is of course compromised by the level of gear that I have at my disposal).
My receiver's crossover was set to 60 Hz for this as it allowed me to apply equalization @ 63 Hz. Does that sound reasonable? The rec'r has a crossover slope of 12dB/octave and 1 sub pre-out which I have split. The subs have 24dB/octave slopes but I have them set to LFE so the x-overs are bypassed. How does that part sound?
Finally I am wondering how all that will fit into the 5.1 deal and if I will need to make further adjustments for that. That's enough for now.
Help a fellow audioholic take the next step
Alex
