just wondering are these the same cables ???
TLS Guy Seriously, I have no life. May 18, 2008 #2 motogp34 said: just wondering are these the same cables ??? Click to expand... Wire is wire. So why does it matter?
TRT Junior Audioholic Aug 8, 2008 #3 motogp34 said: just wondering are these the same cables ??? Click to expand... Just to go on record: I would have liked an answer.
mtrycrafts Seriously, I have no life. Aug 8, 2008 #4 motogp34 said: just wondering are these the same cables ??? Click to expand... If you bundle that Canare to 2 conductor, it will be the same ga and that is what matters unless looks are important. Then, that aspect is your choice. Cost doesn't determine much about performance.
J jamie2112 Banned Aug 8, 2008 #5 Cost doesn't determine much about performance.[/QUOTE] You got that right.....
C cornelius Full Audioholic Aug 9, 2008 #6 I've often wondered the same thing. TLS Guy said: Wire is wire. So why does it matter? Click to expand... If it is Canare in a fancy (and IMO ugly) jacket - then obviously they're WAY overpriced. This is why I like BJC, they tell you exactly what you're getting...
T Toka Enthusiast Aug 31, 2008 #7 motogp34 said: just wondering are these the same cables ??? Click to expand... Have you written them directly and asked? The specs sure look similar, at any rate.
