deconstructer
hi i posted this yesterday but i cant seem to find my post so i'll post this question again...i ran the specs of the peerless sls 830669 12" woofer in bassbox pro and the db rose up in the freq range of 30 to 200 to about 115db-spl and from there it start's to drop and in the manufacturers spec list it shows that the woofer is good to about 1000hz so if the program(bassbox) showed me a rise in the db's in the 30-200 region and i want to crossover in the 1000 region wich is about 91 db then wont i have sound problems because of the loudness of the 30-200 hz region http://www.tymphany.com/datasheet/pdf/pl/830669.pdf
thats the spec sheet for the sub
and also...can someone tell what are the pros and cons of using a first order crossover as opposed to second order and third order and the fourth order crossovers????:confused:
