Richard Gray equipment
Harrison476
Does anyone have any experience with Richard gray Power products? They sure do have some interesting equipment and aproachs. I am wondering if their improvements in audio and video claims with their products are real and equal to the cost?
Thanks
avaserfi
avaserfi
From the looks of it I wouldn't think they are worth it. If you want quality protection and/or a power supply look at APC or another company that releases UL approved equipment.
Also, I wouldn't bother spending the money to replace power cords as that is snake oil to the max.
This stuff seems to be marketed towards the crazy audiophile.
Harrison476
Well, I hear what your saying! and thanks for your comment. I had a local company person call me about inguiry I made online. He says you will see big improvements in bass, video, and audio. :eek: He was helpful with a few questions I had about my system. Also he warned about the lightening strikes we have, that I should protect all my other tv along with my theater set up. I have no idea from a techincal standpoint if the gray power cords along with the powerconditioners would help or not. Approaching conditioning the electrical circuit in which the A/V equipment is using is interesting. I would like to see this tested.
Also have you seen the cable Razor Vision for video???? :D
Ask the person who called for measured results for those audio benefits, not imagined ones:D
If you are in area of lightning and surges, you do need protection for them and most likely by other products. Direct lightning or major close ones may not prevent damage though.
Harrison476
yep ,..... I was going to buy some expensive HMDI cables, read the form-located monoprice, got three new 1.3a cables. ordered quality speaker wire with banana plugs( screw type). Need some heat shrink tubing. I am almost there. thanks guys
