zoysia said:
So when people say hard button remote they mean it is not a touchscreen.
Your typical remote that comes with equipment is a hard button remote - there are actual physical buttons to depress.
LCD Touchscreen are the types where you have to actually touch the screen to execute a command. Some of them just allow text labels and advanced models like Prontos and the high end line of Home Theater Master allow graphics and icons. Some touchscreen remotes also have hard buttons (the very old MX-1000 was like that).
The URC and MX series from HTM are hybrids. They have an LCD screen that you can label yourself with 5 characters but they are not touchscreen (with the exception of the URC-300). There is a hard button next to the label on the lcd screen. The URC-300 which is a touchscreen also has hard buttons.
I am partial to the HTM remotes, having owned an MX-500 and now an MX-350. I feel the hybrid approach is the best - hard buttons you can depress by feel and an lcd screen to put commands that don't map nicely to the name of the command on the original remote; eg. in the Cable mode of my remote I have LCD buttons for A, B, and C which control aspects of the cable box's program guide. Without the lcd, you would end up choosing an unused button like say +10 to hold one of those commands. I can find those buttons by feel too because I programmed it and know which button is which. If I want A, I can put my finger on the bottom lcd button (C) and move up two to find A.
