As a Crestron programmer, I have a bit of a unique perspective on this... I want you to remain as confused and as stupid as possible about all things A/V related.
Seriously, manufacturers are incredibly full of themselves about all things that they produce. The concept of serial control or discrete IR functionality is hit-or-miss with many companies and when they do offer it, they often don't implement it correctly.
HERE ARE SOME BASIC CONCEPTS MANUFACTURERS DON'T GET...
1. Discrete IR commands to power on, power off, and input select your components. Philips, one of the original companies to produce programmable remote controls has LACKED discrete IR codes for many of their products for years. Sony is great about it... sometimes. It's always hit or miss. NOBODY is good about publishing these codes on the go-to website for discrete IR codes -
www.remotecentral.com
2. Rear IR input. Come on! If you are going to make a device that is designed to be integrated into a HT system, then put an IR input port on the back so that an IR repeater system can talk straight to a device and you don't have to put a mouse emitter (about the size of a raisin) on the front of your $1,000+ piece of gear!
3. RS-232 codes are not mystic. Stop protecting the serial codes for your products. Publish them, put them on the internet, make them known. Sanyo does it... I think Yamaha does it. Samsung has serial control that they will NOT release! Other companies (like Tascam) have convoluted serial protocols that are twenty steps less than perfect yet they act like they have created golden water with their designs. Get real.
There is no way that manufacturers are going to get together to standardize on control of their products. It would require a very serious commitment on the part of five or six of the major manufacturers and a lot of solid input from design engineers for them to figure it all out. Wi-fi is definitely the solution, something like Inifinet architecture where every device is a transmitter/receiver and auto identifies on a network. But, it then comes down to having everyone agree on every aspect of it.
I look forward to a long and fruitful career.
