Rewire a 3 channel lcr to use as a 1 channel center
Bigblu2u
Hi everyone.
I have a Pinnacle QP9 3 channel LCD that I would like to rewire to use it as a single center channel. There are 6 woofers and 3 tweeters, and not sure if I would need to switch out the crossovers or use just 1 of the 3. Or is there a way to connect the existing 3 sets of terminals and maintain a 4 to 8 ohm load. The receiver is an Onkyo TxRz 830, in a 7.2.4 system. My current speaker is a James Audio custom built center channel
Thanks!
WaynePflughaupt
WaynePflughaupt
There’s no point in re-wiring it. Just use either the center channel input (8-ohm), or parallel the two L/R connections (4-ohms).
Regards,
Wayne A. Pflughaupt
