Hey everyone, i'm new to this forum =]
Well my DVD player has broken down, please help me (well it's my dad's and his angry)
I have a DVD/VIDEO CD/CD PLAYER Yamaha DVD-S80 (I think that's the model name) and when i insert a disc, it says
H07
Does it stand for hot? Or does it mean H Zero Seven. I can't play any type of disc, DVD, VCD, normal CD. That keeps popping up and when i try taking out the disc (pressing open), it lags hard.
In the owner's manual it says (in troubleshooting section):
Unit displays:
"H _ _" - __ stands for a number.
7 - You inserted a disc that the unit cannot play: insert one it can. (I tried my old dvds that i watched on the same unit that had worked, but it still comes up, so it's not the discs.)
- Trouble is likely to have occured. The number following "H" depends on the status of the unit.
Reset Procedure:
Press [standby/on] to switch the unit to standby mode and then back on. Alternatively, press [standby/on] to switch the unit to the standby mode, disconnect the AC power cable, and then reconnect it.
I tried it and it didnt work?!
Also, in another section it says
7 - Condensation has formed: Wait 1 to 2 hours for it to evaporate.
7 - This unit cannot play discs other than DVDs, CDs, and VCDs
7 - The dirty disc may require cleaning
Condensation has formed, wait for 1-2 hours --- is that with the unit on?
Can't play discs other than DVDs etc; --- I was trying to play discs that it can play.
Cleaning ---[/b] tried it
Also, you can't place the unit on amplifiers or equipment that may become hot. (Didn't see that till today which is over 2 years now that it has been resting on the amplifier)... is it wrecked for sure?
Please help me people..
Any help is appreciated!!!
~liljason951
