Hi there,
I have a similar problem, which I am getting no where fast on. In this case, I have an RX-V2500 A/V connected to a toshiba HDTV, via component cables. I also have a Motorola HDTV DVR settop box, also connected to the V2500 via component video cables, and with audio via toslink. The cable stuff works fine, but I can't get the Yamaha GUI to send clean to the TV. The same cables send the cable signal, but the GUI is tripled and fuzzy on the top of the screen. I turned off the Cable box (in case this was overlaying for some reason), with no change in the ugly GUI menu.
Am I missing something here?
Thanks, Barry
1. Cable to A/V via component V and toslink audio
2. A/V to Toshiba 30HF84 via component video
3. Audio connections to 5.1 channel speakers (Paradigm MiniMo/CC370)
All wonderful except scrambled GUI menu.
Not alot of info in the manual.
No EMAIL response from Yamaha after three tries in 7 days!!!
