Replacing Yamaha RX-v850
RickN
My current Yamaha receiver will not turn ON and it is time to replace. I would like to fix, but it might not be the most economical way to move forward.
I currently did use the receiver for Surround Sound, with 2 front speakers, two rear speakers, one center speaker and one sub woofer. Along with a Russound Speaker selection switch to power 2 outdoor speakers and 2 remote room speakers.
What would be the equivalent Receiver today that can replace this module? Thank you for any guidance.
W
waxey
yamaha RX-v850
Could not find the 850 on the yamaha archives are you sure of the model number? also are you looking to upgrade from a 5.1 to 6 or 7.1 with hdmi etc. and do want another Yammi?
mpompey
mpompey
Depending on your setup and plans you would probably do good with the Rx-v1065 or Rx-V1900. What speakers are you looking to play? What is the size of your room?
