It will work fine, but If you don't sit far off axis, it won't be a huge improvement since the LSi9 is similar to the center in driver compliment. I do think the LSi-9 has a better cabinet than the LSiC. if you plan to stand the LSi9 vertical, you can try that with the LSiC also. Is there a problem with the LSiC?
