Replacing sub in loudspeakers
absinthe
Hey ppl, so my SM-215 Infinity loudspeaker subs are blown. I was thinking about replacing the 10"inch subs with a car sub. Would I have a any issues if I did? I can order the normal subs from Infinity. But I figured for the price I might be able to use car subwoofers that are better quality and higher watts. I would appreciate any help on the subject, thanks all :)
Sheep
Sheep
Is this the woofer in a full range loudspeaker or a subwoofer driver?
If its a woofer from a full range, I would not use a car sub. Most of them are 4 Ohm and inefficient to drive. I also find them to sound worse then Home audio drivers of the same price.
If you can get the stock driver use it. Its going to work with the box and crossover unlike another random driver.
SheepStar
absinthe
Yep it's a full range loudspeaker, thanks for the reply :)
