Replacement for OneForAll 9910 remote
Quadzilla
Quadzilla
Hello,
I'm looking for a replacement for my OneforAll 9910 universal remote. The main feature I like of the 9910's is its ability to control components in another room via RF/IR . I tried the URC RF 20 but wasn't too pleased with it. The thing I liked about the 9910 compared to the URC unit was being able to press one button to select a component. I also liked the 9910's backlight function that could be activated at the press of any button rather than having to press a dedicated light button on the side of the unit then pressing your desired functions as on the URC. This may seem like nit picking but I've got limited dexterity so it's pretty important to me.
Can someone please recommend some other infrared/radiofrequency type universal remotes similar to the OneforAll unit? My budget is approximately $125. I only need to control seven different components in the range isn't very far at all, probably less than 30 feet.
If the other one died, why can't you replace it with the same? The company is still in business, or maybe they can save your program and load it into a replacement.
As far as pressing one button to control a component, just about any non-activity based remote can do that, but the buttons need to be mapped for it. The URC will definitely do what you want.
