Replacement earpads for RBH HP-1B?
a-dogg
The pads are a touch small for my ears. Since the cans are rectangle, not oval, can you advise of options for larger earpads? Will any oval earpads work as replacements, assuming I get a larger size? If not, are there rectangle ones you can recommend?
