Replacement bulb for Vidikron Vision 30 HD DLP Projector
F
funkyerdoc
Looking for any advice on where I can purchase a replacement bulb for my Vidikron Vision 30 HD DLP projector.
Thanks for any help
F
funkyerdoc
Thanks for the website
But it lists bulbs for Vidikron models 10, 12, 15, 50, 70 which all appear to be the same bulb
I have a Vision 30, which is not listed.
Does anyone know if a bulb for another model will work in the Vision 30?
lsiberian
lsiberian
The best way to find out would be to take out the current bulb and see if they look the same and have the same parameters. You could also call the store and ask them. usually if it won't work they will accept returns.
allargon
Thanks for any help
Check E-bay as well. That's what those of us (who are frugal) with rear projection displays do.
BMXTRIX
BMXTRIX
Probably not very helpful, but I would give them a call directly to get the exact make/model of the lamp.
Since this is a Runco company, you should expect that this will not be inexpensive, and may be 100% only available from them directly at whatever price they decide to charge you.
