chaoster
I have a 42 inch Olevia LCD. It's a little more than 3 years old. Two days ago the LCD just shut off while I was watching it. It would not turn back on. It was late went to bed. The next day before work I unpluged it for several minutes and pluged it back in. It worked. Went to work, came home to watch TV and after a little while it shuts off again. This time I unplug and it turns back on but the screen is very dark. You can barely make out the images. With the DVD player the movie is a little brighter but picture is green. My question is it worth fixing or should I just buy a new TV? I don't even know who is able to service a Syntax LCD.
Pyrrho
Pyrrho
Hmmm....that is a tough call, without knowing how much it would cost to fix it. I would probably buy a new TV, as newer ones tend to be much better than the older ones, but I would hate to say just buy a new one if it would turn out to only cost you $100 to fix your old one. If you can get an estimate on the repair without spending too much money, that might be your best option. Of course, if it turns out to be such that a repair will be expensive, you will have spent your money just to find that out. Is it worth the cost of an estimate to know if it is worth fixing or not? That, I think, is the question you should answer for yourself.
Since unplugging it seemed to do something, you might want to unplug it for a couple of days, and then try it again. You may also want to reset the TV to the original factory settings (your manual should probably be able to help you do this simply), and then, if it seems to work properly, recalibrate it as you did before. If not, then find out what an estimate to repair would cost. If it would cost a small amount of money to get an estimate, then it would probably be worthwhile to do that. If it would be expensive to get an estimate, I would just buy a new TV. I personally would not want to spend more than about $50 on an estimate, but you must decide for yourself what it is worth to you to know what it would cost to fix it.
If you buy a new one, and are on a budget, I recommend looking at Toshiba. They typically cost only a little more than off brand sets, and are generally good.
Midcow2
Midcow2
wow a tweener descision
I just had to have the power supply fixed on a WS- 55859 Mitshibishi TV that was 5 years old, $505 ARRRG! At the same time I asked about replacement of LCD bulb and it was around $400. In each case the labor was at least half. They did say replacement of a LCD bulb was easy if you could find the bulb.
The way prices have come down, you will probably be paying more than half of what an new LCD would cost just to repair your old one!
What I did find was that the service costs and charges varied greatly. Call several places! I found one place that was as low as $65 to come out and diagnose and then if I went with them they would deduct the $65 service cost. Others were as high as $149 diagnostic charge, plus a $49.95 trip charge.
Good luck.
chaoster
I think I'm in the market for a new TV. Spoke to a place that charges $89 to find out what wrong. He said labor would be about $200 to $300 on most repairs he's seen. It would be about $500 for the repair on average. Olevia told me a new board would be $200. So $500 sound about right. So no more off brands for me. Thanks for all input.
