Why make this so complicated, my wife used to do all the play stuff for the kids, and a train would be a couple sound blocks rubbing together and a whistle, behind the black screen the person making the effects would just run from one side to the other.... If you really want to use a speaker, I would get a single mono pole speaker and have someone run across the black screen with it on a long cable.... And as for a cd player, I would get an active speaker and use an mp3 player with the sound clip down loaded to it, there are a ton of sources on the net for effects... If you do want to do it with multi speakers I would use just 2 speakers, then through an avr one on each side of the stage should give the effect...
