REL S/5 (Serie S) Subwoofer Overview
HTKamikazee
Audioholics Sheriff
When it comes to subwoofers, we can find several amazing brands like REL. This company has been known for their ergonomic and beautiful products and their new Serie S Flagship, the Majestic S/5 is proof of this.
The S/5’s driver features an all-new alloy cone structure that, according to the company, takes their mid-level product to a performance that exceeds their reference products of only a few years ago. Their engineering team reduced its moving mass, with a balanced approach to design to produce more speed than prior designs. Having an active, front-firing driver and a passive down-firing driver makes this subwoofer a very interesting offering from such an admirable company.
Here is a close view at the passive down-firing driver.
But what about power and connectivity?
The S/5’s features a powerful NextGen2 550W digital amplifier - a design that has powered several REL products in the past.
Take a look at the back plate of the amp.
In addition, LongBow Wireless Connectivity permits signal to be sent wirelessly within the same room to approximately 45 feet.
Check out the following features and specifications for more details. Also don't forget to share your impressions.
FEATURES:
  • Continuous Cast™ Cone Bass Engine.
  • Carbon Passive Radiator.
  • NextGen2 550W Digital Amplifier.
  • Freedom LongBow™ Wireless Connectivity.
SPECIFICATIONS:
  • Speakers:
- One 12" long-throw front-firing active woofer.
- One 12" down-firing passive radiator.
  • LF Response: 21Hz @ -6 dB
  • Frequency Response: 24Hz to 140Hz ±3dB with its crossover control set to 120Hz, and from 20Hz to 95Hz ±3dB with its crossover control set to 30Hz.
  • Inputs:
- Hi Level Neutrik Speakton
- L/R Low Level phono
- LFE phono
- SMA for wireless
  • Gain range: 80 dB
  • Power output: 550 watts RMS
  • Phase switch: 0/180
  • Amplifier type: Next Gen II Class D
  • Mains input voltage: 220-240/110-120
  • Fuses:
- 5A semi delay (220V)
- 0A semi delay (120V)
  • Dimensions: 17.5" x 18" x 20"
  • Weight: 80 lbs.
PRICE: $2,599.99
shadyJ
Speaker of the House
Staff member
$2600 for a 550 watt 12" with a passive radiator?
Well, it's shiny anyway.
